ibrahim.menem
Beginner
How to remove class-map using C API
I'm trying to use C API to delete class-maps, I tried using :
1.  onep_policy_entry_op_remove_cmap
2.  onep_policy_cmap_op_delete
but with no success , also for some reason I get additional acl with name udb_temp_acl...
I'm using All-in-one vm, with sdk version 1.2.0.173
What is the correct way to delelet class-maps? why I get the udb_temp? if this is a platform problem where I can get the most updated API compatibility matrix?
Thanks in advance.
Ibrahim
1 ACCEPTED SOLUTION
onep_policy_cmap_op_delete does work correctly, the problem was trying to reuse the op_list variable! creating new one solves the problem
6 REPLIES 6
Joe Clarke
Hall of Fame Cisco Employee
Are you trying to remove a configured class-map, or one installed through the onePK API?
Installed through onePK using the bulk method from the  Datapath tutorial
well, it removes the cmap content but doesnt remove the entry!  I get a none entry
Joe Clarke
Is this with the newly proposed code of:
/* modify an entry op */
rc= onep_policy_pmap_op_entry_remove(pmap_op,entry_handle,&entry_op) ;
if(rc != ONEP_OK){
LOG(ERROR, POLICY , "entry remove failed (%d) %s" , rc, onep_strerror(rc));
It does work when preceded with onep_policy_pmap_op_modify, I wanted to leave the thread clean indicating that the "old correct answer" was partially correct (I couldn´t edit it).
Still wondering why it is so complicated to find the correct calls needed to achieve such a basic functionality
Content for Community-Ad
