iosxr xconnect ned issue
khgrant
Hi team,
I have the following config device config:
xconnect group EACCESS
  p2p EACCESS_2764760001
   interface Bundle-Ether100.34
   neighbor ipv4 97.76.237.3 pw-id 27647601
    pw-class RAW-MODE-RPW
After my service creation, im adding additional p2p under same xconnect group successfully:
  p2p EACCESS_34567830
   interface Bundle-Ether100.3000
   neighbor ipv4 10.0.0.1 pw-id 130345678
Now when I want to delete the service I get the following dry-run to perform:
commit dry-run outformat native
device tlab79-dar2 {
  l2vpn
   no xconnect group EACCESS
  exit
This will destroy my other p2p I had previously configured under the xconnect group
Any leads how to handle this would be much appreciated
Noam
1 ACCEPTED SOLUTION
khgrant
Closing this thread with the solution:
With the assistance from Mike Leske, we found the issue and fixed it
The good device was running XR 5.1.3 and the bad one was running XR 5.3.1
So in 5.3.1 there is an option for redundancy configuration which adds an additional configuration level closing:
l2vpn
logging
  pseudowire
pw-class RAW-MODE-PW
  encapsulation mpls
   transport-mode ethernet
pw-class ATOM-VLAN-CW
  encapsulation mpls
   control-word
   transport-mode vlan
  encapsulation mpls
   redundancy
    one-way
xconnect group ELINE
  p2p CM_ACB3-13AC-8EB2
   interface Bundle-Ether100.178
   neighbor ipv4 97.76.237.3 pw-id 178
This was fixed by modifying the XR NED and adding the following:
container redundancy {
  tailf:cli-add-mode;
  tailf:cli-mode-name "config-l2vpn-pwc-mpls-pw";
  leaf one-way {
    tailf:cli-full-command;
    type empty;
Noam
5 REPLIES 5
khgrant
This is the relevant section from the NED:
    container xconnect {
      tailf:info "Configure cross connect commands";
      // l2vpn / xconnect group *
      list group {
        tailf:info "Specify the group the cross connects belong to";
        tailf:cli-mode-name "config-l2vpn-xc";
        key name;
        leaf name {
          type string {
            tailf:info "WORD;;Name of the cross connects group";
list p2p {
          tailf:info "Configure point to point cross connect commands";
          tailf:cli-mode-name "config-l2vpn-xc-p2p";
          key name;
          leaf name {
            type string {
              tailf:info "WORD;;Name of the point to point cross connect";
          // l2vpn / xconnect group * / p2p * / interface
          list interface {
            tailf:info "Specify the attachment circuit";
            tailf:cli-suppress-mode;
            tailf:cli-delete-when-empty;
            key name;
            leaf name {
              type string {
                tailf:info "WORD;;Interface Name";
tailf-ned-cisco-ios-xr
  revision 2015-05-15 {
    description
      “3.9.0.9
khgrant
This looks strange - did you execute a sync-from before creating the service - i.e was NCS aware of the previous existence of the /xconnect/group[name='EACCESS'] list entry when the service was created.
khgrant
Klacke, thanks for the pointer, this is true, the xconnect group will be removed once only one p2p connection exist under the group otherwise it will remove the specific p2p entry for the service
My problem is that one of the XR in the setup doesn’t populate the l2vpn xconnect subtree (that’s why the xconnect group was removed as it was the only one ncs know of) under the device model while it is on other device I will dig further tomorrow try figure why is that
khgrant
Ok - yes that's how it works.
Remember I wanted you to do show | display service-meta-properties
It didn't show anything, I remember now, that probably only works with the Juniper cli
> switch cli
> show ....
This shows refcounters, and backpointers, try it.
If something exists on the dev, service tries to create it, refcount becomes 2, and then when we del service, the container/list-entry remains
OTOH, the stuff I saw on your setup today still looked real strange.
/klacke
khgrant
l2vpn
logging
  pseudowire
  encapsulation mpls
  encapsulation mpls
   control-word
   transport-mode vlan
  encapsulation mpls
   redundancy
    one-way
  tailf:cli-add-mode;
  leaf one-way {
    type empty;
Noam
