khgrant
Issue with maapi.load_config
Hello Team,
I managed to have the python maapi.load_config with the help of Fredrik. All is fine, I am able to connect from a client machine to the nso server but there is a problem when fetching the xml file.
When I was running the script I was having this error:
root@goserver01 load-merge]# python2.7 load-merge.py /root/nso-41/load-merge/ns.xml
Will merge data from /root/nso-41/load-merge/ns.xml
ok
Traceback (most recent call last):
  File "load-merge.py", line 20, in <module>
    main()
  File "load-merge.py", line 15, in main
    maapi.load_config(s.sock, th.th, maapi.CONFIG_XML, xmlFile)
_ncs.error.Error: system call failed (24): No such file or directory
So I thought I would place the file on the server at that path and it all worked.
So apparently this call:
is looking for the xmkFile on the server and not on the client from where I am running the script.
Is this a bug or is there a way around it? Maybe I need to configure more parameters?
Thanks for your help,
Cheers,
Francesco.
4 REPLIES 4
khgrant
Francesco,
That's right, and that's how it's supposed to work. A more convenient function for you might be the related
maapi.load_config_cmds()
which accepts a string instead of a file. If the file you have is local, just load the contents and feed it in.
Best Regards,
/jan
khgrant
Hi Jan,
thanks for your reply.
I have looked at that function, it is defined like this:
load_config_cmds(...)
        load_config_cmds(sock, thandle, flags, cmds, path) -> None
        Loads configuration from the string 'cmds'
        Keyword arguments:
        sock -- a python socket instance
        thandle -- a transaction handle
        cmds -- a string of cmds
        flags -- as above
Do you know what the path parameter is? How am I supposed to load the content of the full xml file? If I normally read a file by line in python, it then creates a list of strings.
Is there any example of the usage of this command that could clarify a bit?
Thanks for your help!
Cheers,
Francesco.
khgrant
Francesco,
path
) -> None
         Keyword arguments:
         flags -- as above
In python you can read the entire file using the file read() method.
with open('file.xml', 'r') as xml_file:
    xml_text = xml_file.read()
The path parameter allows you to lock-in (chroot) the commands to only be able to touch a certain part of the data model. You can use "/".
Makes sense?
Best Regards,
/jan
khgrant
Hi Jan,
thanks for replying back!
I had actually tried it this morning, the only difference is that I had set the path to an empty string but it worked anyway.
So finally all seems to be working Now I can provision a new network element to nso, push a config file (from a script residing on a different server than the NSO)  and I can thus accomplish a kind of zero config config  to a newly spun up virtual network element.
Thanks for all your help!
Cheers,
Francesco.
Content for Community-Ad
