khgrant
JSON RPC 'commit' method "flags" values
Hi NSO experts,
I’m trying to achieve "commit no-networking" via JSON RPC as part of my JSON payload. We have 'commit dry-run' and 'commit working just fine.
What I’m trying achieve: commit no-networking
While reviewing the “commit” method in NSO 4.x Web UI PDF document, it shows that I can use “flags” with a numeric value to achieve different results. When I use ‘3’ or ‘1<<3’ which is for "no device manager”, the transaction still carries out the commit. What is the flag value that corresponds to ‘no-networking’ option in commit method ?
Is there a different method I should be using ? What am I missing ?
Thanks & Regards,
Nick Khemani
7 REPLIES 7
khgrant
I got very similar question today from a different customer, they are asking if it is possible to skip out-of-sync-check when using the REST interface.
Would appreciate any feedback.
Thanks!
Michel
khgrant
For REST, use query parameter  no-out-of-synccheck : Continue with the transaction even if NCS detects that a device's configuration is out of sync
See ncs_northbound-*.pdf  for all supported parameters.
khgrant
Try number 8 (= ‘1<<3’ ). To combine ‘1<<3’ and ‘1<<2”, try number 12, etc.
khgrant
Hi everyone
JSON-RPC commit method will learn many flags, including no-networking, in NSO 4.1.1.
The functionality is not available in previous versions.
As for the REST API, see the user guide for Northbound APIs -> REST API -> Resource Examples -> Examples using POST, PUT and PATCH -> Making use of the commit flags.
Andrei
khgrant
Thanks Andrei and Richard. Any idea on the release date for NSO 4.1.1 ?
Thanks & Regards,
Nick Khemani
khgrant
Could you please share the user guide / examples for using North bound API using JSON-RPC  ?
Thank you.
Rajashekhar S
khgrant
Rajashekhar – please refer to the Web UI PDF document as part of the NSO release you are using. For e.g., I use: "nso_webui-4.0.2.pdf"
Thanks & Regards,
Nick Khemani
Content for Community-Ad
