Greetings,
I have no experience with licensing for UCS and I was wondering where I can find out how licensing works with UCS. Hopefully, someone has a video somewhere. Otherwise, if someone can send links where I can look at what kind of licensing the UCS has in version 2.2(1b). Also, what kind of licensing is in 3.2(2d). And finally how you go about moving your licenses from 2.2(1b) to 3.2(2d). I'm assuming they are tied to MAC or S/N so when the Fabric Interconnects are replaced I would think they would need to move to the new ones.
Currently, they have 6120XP's running 2.2(1b). The plan is to go to 6248UP's running 3.2(2d). Also, if you could provide the best way to see what they have now that would be great. Unfortunately, the tech support export does not include licensing
Thanks in advance!
