When a device is netconf capable and has a full yang model – how does that change the service template model?
Currently with our CLI based NED – we use a lot of XML/Yang based service templates.
Thanks, JA
Solved! Go to Solution.
Hi JA,
Whether a device is NETCONF or not has no bearing on the templates. The template will always reflect the device model NETCONF or CLI. For a device which switches from CLI to NETCONF based NED will also require an updated template to support the newer device model which will most likely be quite a bit different than the CLI model.
-Dan
Hi JA,
-Dan
Hi JA,
once vendors converge to natively support standardised YANG models, e.g. L3SM, open-config, etc. , template creation in multi-vendor projects may become easier, because we can use the same templates for e.g. cisco and juniper.
Still, new features only 1 or the other vendor has requires additional template creation.
Mike
Mike,
And remember that IETF portions and vendor specific portions have different namespaces, which makes co-existence very simple.
These are all NSO differentiations against the competition.
Roque
