Hi -
Is there a way to explicitly ignore case while typing on netsim devices ?
VO0(config)# interface v?
% Invalid input detected at '^' marker.
VO0(config)# interface V?
Virtual-Template Virtual Template interface
Vlan Catalyst Vlans
Narayanan
Solved! Go to Solution.
The ConfD CLI has support for this, it boils down to a setting in the confd.conf that is used by the individual netsim devices.
$ man confd.conf
/confdConfig/cli/caseInsensitiveKeys (xs:boolean) [false]
caseInsensitiveKeys is either "true" or "false". If "false" then
all user defined instance names must have correct case. If set to
"true" then case is mostly ignored. Note that if set to "true" then
all data model files and clispec-files must be written with this in
mind. You cannot have two elems that conflict in case.
Thus if the netsim portion of the NED has a confd.conf template with this setting, logging in to a netsim device, the CLI will be "mostly case insensitive"
Try to modify your NED - if this is the official IOS NED, it's a whole different business to convince the IOS NED developers that this is a good thing.
Seems to be a pretty confused feature IMHO
/klacke
Hello Narayanan,
I think its not about netsim only even for actual device it behaves like same.I have also tried to found to avoid this case sensitive feature but no luck.
I will keep you updating if I find something useful.
Hi Tamal -
Thanks for the reply! I don’t see the real devices are case sensitive, I just cross verified with one of the IOS real device and here’s the result I see..
svlpdn-dc-gw1(config)#interface V?
Vif Virtual-Template Virtual-TokenRing Vlan
VoaBypassIn VoaBypassOut VoaFilterIn VoaFilterOut
VoaIn VoaOut
svlpdn-dc-gw1(config)#interface v?
VoaIn VoaOut
So I assume its a constraint on NSO Netsim.
It would be great, if someone from core development team can comment on this limitation.
Narayanan
$ man confd.conf
/klacke
Thanks Klacke!
XML tag /confdConfig/cli/caseInsensitive for me..
Narayanan
