NFV Management and orchestration
eugenio.raciti
Beginner
Beginner
I have a doubt about how should be a basic workflow of creation of VM, VNF and then model a device and a service.
With NCS I create:
  • the device model (NED) and sync it with the device configuration
  • the service model (for example vLAN or VPN)
But that suppose I already have the devices.
But If I want to be also the administrator of the NFVI?
Does the orchestrator have the capability to interact directly to a VIM in order to create virtual device?
Should  NCS (as orchestrator) interface directly with a VIM to ask the creation of a VM
or NCS should interface to the VNF Manager (ESC)  and it will interface with the VIM?
Eu
19 REPLIES 19
Hi Raffo,
The ESC talks to OpenStack using REST as far as I know.
ESC also contains a ConfD instance which provides for NETCONF communication between NCS and ESC.
However, these are ESC internals.
I don't have a flow diagram to share with you right now.
However, you can run the example and examine ncs-java-vm.log and correspond it to the code. I guess it would give you some idea about interaction between NCS and ESC.
Ajay
khgrant
FYI Experts - NSO 4.0 should become available in early August. Once released it'll be loaded to DevNet.
Thank you.
Khara
has NSO 4.0 been released?
Raffo
Based on DevNet, the latest NSO available is 3.4.2.
Cisco DevNet
khgrant
Team -  Quick Heads Up.
NSO 4.0.1 will be loaded and available on the NSO DevNet portal this week. Have a productive NSO week, Experts!
Khara
