09-01-2016 08:30 AM
Hello folks,
I wanted to check about a GUI issue with NSO 4.2. We are planning to use this GUI for a demo and hence wanted to make sure if this issue can be resolved.
Issue:
The issue is related to the "enumeration" data-type. In the Yang model we have containers which have lists which in turn have leaves of type “enum”.
What we noted was:
Below are the Yang snippets with the respective screenshots of both the enum fields.
Appreciate any feedback on this.
Enum field inside container:
Yang:
container boot-image {
leaf server {
tailf:info "Image Repository Server IP Address / hostname";
type string;
leaf username {
tailf:info "Image Repository Server Username";
type string;
leaf password {
tailf:info "Image Repository Server Password";
type string;
leaf protocol {
tailf:info "Protocol used for image file transfer";
default ftp;
type enumeration {
enum ftp;
enum sftp;
Enum field within a list inside a container:
Yang:
container plan {
tailf:info "Select the upgrade steps and their order";
list step {
key "step-name";
unique step-num;
leaf step-name {
tailf:info "Step name";
default copy-os-boot-image;
type enumeration {
enum copy-os-boot-image;
enum save-configuration;
enum set-boot-priority;
enum cut-interim-cdr;
enum newcall-reject;
enum show-subscribers;
enum flush-subscribers;
enum synchronize-file-system;
enum copy-running-standby;
enum change-boot-image;
enum pre-upgrade-show;
enum post-upgrade-show;
enum reload;
leaf step-num {
tailf:info "Step position in the plan, i.e. 1st, 2nd, etc.";
type uint16 {
range "1..11";
leaf step-wait-time {
tailf:info "Time (seconds) to wait before running this step. (default: 30)";
default 30;
type uint16 {
range "0..600";
leaf enabled {
tailf:info "Is this step enabled and included in the upgrade execution?";
default "true";
type boolean;
Giri Venugopal
09-01-2016 08:31 AM
Hi!
Bug. Please submit a TAC ticket
