NSO External Authentication not working for Web GUI
Hi Team,
We are facing a strange problem after turning on the external authentication through AAA for the NSO.The ‘curl’ and ‘ssh’ from the local host into the NCS works fine.The ‘curl’ also works fine from a remote host into this ncs into port 8080.The problem is with the ‘Web Gui page login’
When we try to login through the 'web gui’ page it says the authentication failed but the ncs 'audit logs' show that the external authentication has been successful.
Audit log captures -
<INFO> 24-Aug-2016::18:11:15.171 sngkc-nfv-nso-2 ncs[29765]: audit user: nsouser/0 Logged in over ssh using externalauth, member of groups: ncsadmin
<INFO> 24-Aug-2016::18:11:22.070 sngkc-nfv-nso-2 ncs[29765]: audit user: nsouser/0 Logged in over ssh using externalauth, member of groups: ncsadmin
(END)
Web Gui – what we see
Everyone's tags (4)
3 REPLIES 3
Highlighted
Re: NSO External Authentication not working for Web GUI
<Second Try>
Hi Team,
Has anyone come across this issue?TAC case is open at the moment.
Appreciate any inputs if anyone has come across this issue before.
Vineet
Highlighted
Let me answer here too for later reference.
I found that it's due to a bug, and it's fixed in 4.1.2 for 4.1 branch.
NSO 4.2 has the fix already.
External authentication has a feature to ask user for any warning.
ncs.conf has the switch how the warning should be treated.
<aaa>
   <expiration-warning>prompt</expiration-warning>
</aaa>
This config is there at default for system install.
To workaround, remove this or change it to ignore.
Akira
Highlighted
HI Akira,
Let me thank you here as well
Its indeed was the mentioned bug and the workaround works.We tried it at out customer’s environment and its working.Thank you.Totally appreciated!
Also extending thanks to the guys who were helping out here – Michel, Fatih and Tamal.Thank you guys for all the support!
Best,
Vineet
