NSO not receiving failure in commit from juniper devices
Hi all;
I’m facing a situation where NSO (4.3.1) is showing commit complete even when the real juniper device is refusing the configuration.
Any previous experience with this?
Note:
At the end of this email is the netconf trace file piece for the NSO commit below.
It contains the reply with the error, NSO appears not to handle it correctly.
Trying this demo configuration in the real device:
cfwj-lab1-6014a# set logical-systems TEST security address-book global address-set g_TEST address n_TEST
{primary:node0}[edit]
43@cfwj-lab1-6014a# commit
[edit logical-systems TEST security address-book global address-set g_TEST address]
  'n_TEST'
    referenced address must be defined under address-book
  'n_TEST'
error: commit failed: (statements constraint check failed)
43@cfwj-lab1-6014a#
Now… trying the same configuration from NSO, connected to the same device:
admin@ncs# devices device cfwj-lab1-6014 sync-from
result true
admin@ncs#
admin@ncs# show running-config devices device cfwj-lab1-6014 config junos:configuration logical-systems TEST security address-book
% No entries found.
admin@ncs#
admin@ncs(config)# devices device cfwj-lab1-6014 config junos:configuration logical-systems TEST security address-book global address-set g_test address n_test
admin@ncs(config-address-n_test)#top
admin@ncs(config)# commit dry-run
cli {
    local-node {
data  devices {
                  device cfwj-lab1-6014 {
config {
junos:configuration {
logical-systems TEST {
security {
+ # first
+ address-book global {
+ address-set g_test {
+ address n_test;
admin@ncs(config)#
Commit complete.
admin@ncs(config)# exit
admin@ncs# devices device cfwj-lab1-6014 check-sync
result in-sync
admin@ncs#
config
    address-set g_test
     address n_test
admin@ncs#
========= at this moment I can see that =========
-      NSO contains this configuration and device is in sync.
-      Real device does not have the configuration.
If I do a sync-from, the above configuration is removed.
result true
% No entries found.
admin@ncs#
Generated in logs for NSO commit:
<rpc-reply xmlns:junos="http://xml.juniper.net/junos/12.3X48/junos" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="7">
<<<<in 24-Mar-2017::07:15:59.101 device=cfwj-lab1-6014 session-id=50224
<commit-results>
<<<<in 24-Mar-2017::07:15:59.819 device=cfwj-lab1-6014 session-id=50224
<rpc-error>
<<<<in 24-Mar-2017::07:15:59.820 device=cfwj-lab1-6014 session-id=50224
<error-severity>error</error-severity>
<error-path>[edit logical-systems TEST security address-book global address-set g_test address]</error-path>
<error-info>
<<<<in 24-Mar-2017::07:15:59.821 device=cfwj-lab1-6014 session-id=50224
<bad-element>n_test</bad-element>
</error-info>
<error-message>mgd: referenced address must be defined under address-book</error-message>
<<<<in 24-Mar-2017::07:15:59.822 device=cfwj-lab1-6014 session-id=50224
</rpc-error>
Best Regards Paulo Oliveira
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: NSO not receiving failure in commit from juniper devices
Sorry… all clear!
   “An error was introduced in NSO 4.3 where RPC errors from Juniper  devices was ignored. This has now been fixed.”
4 REPLIES 4
Are you using transactional mode or commit queues?
-Dan
Try NSO 4.4.
There was a bug introduced in 4.3 and fixed in 4.4.
-Don
Highlighted
Hi Don and Dan;
The release notes for 4.4 mention that this affects commit queue’s.
I’m using the transactional (default) mode.
“When using commit queues from JSON RPC and specifying sync the RPC
    would not wait until the transaction was done. This has been fixed.
    Also, if there were any errors when communicating with some devices
    they would not be reported, nor would they be displayed in the CLI when
    executing 'commit commit‐queue sync'. This has been fixed.”
(I will try 4.4)
Best Regards
Paulo Oliveira
Sorry… all clear!
Content for Community-Ad
August's Community Spotlight Awards
