schallagalla
Beginner
NSO System Install webui not openingup
I am trying to do system install NSO 5.2.1.2 on Redhat Server. It was an offline server. so I did installed java and ant rpms manually and installed NSO.
I can do ssh to nso cli, but I can not see ports opening up for webui.  I have only the below running. I tried configuring different ports for webui, but not working.
netstat -tlpn | grep ncs
tcp 0 0 127.0.0.1:4569 0.0.0.0:* LISTEN 5827/ncs.smp
ncs.conf:
<webui>
<enabled>true</enabled>
<transport>
<tcp>
<ip>0.0.0.0</ip>
<port>8081</port>
</tcp>
<ssl>
<ip>0.0.0.0</ip>
<port>8888</port>
<key-file>${NCS_DIR}/var/ncs/webui/cert/host.key</key-file>
<cert-file>${NCS_DIR}/var/ncs/webui/cert/host.cert</cert-file>
</ssl>
</webui>
Please let me know if any pointers.
1 REPLY 1
grew00028
Beginner
Hi @schallagalla  did you find the solution, I have same issue, not able to access GUI on system install
Create
Recognize Your Peers
Content for Community-Ad
