abourges
Beginner
onepk 1.2/1.3 python mediatrace problem
...I'm having trouble scripting a onepk mediatrace application. To get started I downloaded the latest (1.3) all-in-one-vm and looked at the mediatrace tutorial. Executing MediaTraceTutorial.py gives:
# ./MediaTraceTutorial.py
  File "./MediaTraceTutorial.py", line 49
    vty.write('conf t)
SyntaxError: EOL while scanning string literal
=> so I fixed that missing single-quote and tried again:
$ ./MediaTraceTutorial.py
Traceback (most recent call last):
  File "./MediaTraceTutorial.py", line 16, in <module>
    from onep.vty import VtyService
  File "/usr/local/lib/python2.7/dist-packages/onep/vty/__init__.py", line 11, in <module>
    from onep.vty.VtyService import VtyService
  File "/eem-5/shr_scratch/build/nightly/sdk_1.3-nightly/latest/infra/onep/presentation/python/pkg_rel/onep/vty/VtyService.py", line 15, in <module>
ImportError: No module named Shared.ttypes
cisco@onepk:~/onePK-sdk-1.3.0.181/python/tutorials/mediatrace$
=> this very same problem can be found in onepk 1.2 SDK
...is there an easy way to fix that ?
Andy
1 ACCEPTED SOLUTION
miott
These problems have been fixed but the SDK somehow got an in-between version of the tutorial.  Make this import the first one and that will fix it.
from onep.element import NetworkElement
2 REPLIES 2
miott
Michael,
...that fixed the problem Mediatrace.py now works - still have
some trouble with my own application, but that's another problem
Thanks for your prompt reply!
Create
Recognize Your Peers
Content for Community-Ad
