118
khgrant
Problem with id-allocator package (1.4.0)
Has anyone used the id-allocator package that is found on stash ? v1.4.0 ?
I am trying to create a simple pool and and it fails:
admin@ncs(config)# resource-pools id-pool test range start 9 end 10
admin@ncs(config-id-pool-test)# top
admin@ncs(config)# commit
Commit complete.
admin@ncs(config)#
admin@ncs# show running-config resource-pools
range start 9
range end 10
admin@ncs#
Everything seems to be fine but the ncs-java-vm.log throws an error:
<ERROR> 25-Feb-2017::01:38:04.545 RangeSet (id-allocator:Reactive fastmap id allocation)-Run-0: - Failed to setup RangeSet
  1. com.tailf.cdb.CdbException: already exists
            at com.tailf.cdb.CdbException.mk(CdbException.java:64)
            at com.tailf.cdb.CdbSession.create(CdbSession.java:1100)
            at com.tailf.pkg.idallocator.RangeSet.<init>(RangeSet.java:45)
            at com.tailf.pkg.idallocator.IdAllocator.createPool(IdAllocator.java:1118)
            at com.tailf.pkg.idallocator.IdAllocator.run(IdAllocator.java:295)
            at com.tailf.ncs.ctrl.ApplicationLifeCycle$1.run(ApplicationLifeCycle.java:72)
            at java.lang.Thread.run(Thread.java:745)
<ERROR> 25-Feb-2017::01:38:04.550 RangeSet (resource-manager:Reactive fastmap id allocation)-Run-2: - Could not add range {"start":9,"end":10}
            at com.tailf.cdb.CdbSession.create(CdbSession.java:1120)
            at com.tailf.pkg.idallocator.RangeSet.add(RangeSet.java:83)
            at com.tailf.pkg.idallocator.RangeSet.add(RangeSet.java:19)
            at com.tailf.pkg.idpool.IDPool.recalculateRanges(IDPool.java:221)
            at com.tailf.pkg.idpool.IDPool.setRange(IDPool.java:174)
            at com.tailf.pkg.idallocator.IdAllocator.createPool(IdAllocator.java:1136)
All packages (nso-util, resource-manager and id-allocator) are the latest version from stash (cloned):
git clone https://stash.tail-f.com/scm/pkg/resource-manager.git
git clone https://stash.tail-f.com/scm/pkg/nso-util.git
git clone https://stash.tail-f.com/scm/pkg/id-allocator.git
The installation is fresh 4.3.1 installation.
Any ideas ? Should I not be using those ? the package posted on developer.cisco.com is not the latest and is from July 2016.
Rgds,
Luis
1 ACCEPTED SOLUTION
khgrant
Hi Luis,
Great feedback! I’m adding a review of the README.md in our issue tracker, could you find the information you needed in the documentation?
You do need to have resource manager as a required package. I think it’s part of the python package documentation.
BR,
Johan
4 REPLIES 4
khgrant
Hi Luis,
Please use the resource-manager package instead. Version 2.1.1 was released this Friday.
BR,
Johan
khgrant
Thanks Johan,
I figured out yesterday that the resource-manager package now includes the id-allocator.py and ipaddress_allocator.py.
I think documentation in the README.md should include this details, explaining how to use it and everything, I would gladly write something and submit a Pull Request but I was not able to figure out how to get an account on Atlassian Bitbucket.
There is also a typo () in the example that can be found in both id_allocator.py and ipaddress_allocator.py:
(default-py2) [lurueda resource_manager:develop±]$ diff ipaddress_allocator.py.bak ipaddress_allocator.py
21c21
<     import reource_manager.ipaddress_allocator as ip_allocator
>     import resource_manager.ipaddress_allocator as ip_allocator
(default-py2) [lurueda resource_manager:develop±]$ diff id_allocator.py.bak id_allocator.py
14c14
<     import reource_manager.id_allocator as id_allocator
>     import resource_manager.id_allocator as id_allocator
And there is something else, which I do not know if should also be part of the instructions. I had to add the resource-manager package as a pre-requisite in the package-meta-data.xml for the package I am using which is importing the resource_manager.id_allocator package
(default-py2) [lurueda l2vpn:master]$ grep -C1 resource-manager package-meta-data.xml
  <required-package>
    <name>resource-manager</name>
  </required-package>
Can you confirm this is required, I could not get it to work without it. I kept getting the following error:
2017-02-25 22:31:23 - l2vpn :: Traceback (most recent call last):
  File "/opt/cisco/nso/4.3.1/src/ncs/pyapi/ncs_pyvm/startup.py", line 227, in start_components
2017-02-25 22:31:23 - l2vpn ::     pname=pname, cname=cname, main_q=self.msg_sink)
  File "/opt/cisco/nso/4.3.1/src/ncs/pyapi/ncs_pyvm/ncsthreads.py", line 152, in __init__
2017-02-25 22:31:23 - l2vpn ::     mod = __import__(modname)
  File "/private/tmp/nso-python-examples/state/packages-in-use/1/l2vpn/python/l2vpn/main.py", line 6, in <module>
2017-02-25 22:31:23 - l2vpn ::     import resource_manager.id_allocator as id_allocator
ImportError: No module named resource_manager.id_allocator
Rgds,
Luis
khgrant
Hi Luis,
BR,
Johan
khgrant
Thanks Johan,
The README.md is kind of misleading because it does mention that is not a standalone package when in reality I think that this version is quite the opposite. It is a standalone package now in this version.
Resource manager is NOT a standalone package. You will need an 'implementation' package, e.g. id-allocator or ipaddress-allocator.
The easiest way is to download and use the 'Resource Manager Bundle' which you should find in the same place where you found this package.
The id-allocator and ipaddress-allocator should also be available at the same place.
The other thing is that we should have in the README.md an example of how to use resource allocation on a package the reader wants to build (examples for both Java and Python).
Rgds,
Luis
Create
Recognize Your Peers
Content for Community-Ad
