128
khgrant
Reactive fastmap for ESC VNF deployment
As part of a Sunstone/ESC/NCS deployment I am trying NCS to provide day 1 configuration to the spawned Sunstone VM,
based on netconf notification sent by ESC to NCS (see below example). So basically:
-          NCS will get the ESC netconf notification shown below.
-          With tenant/vmid info it will query openstack to get the IP address (note there could be several of them and a particular one needs to be picked).
-          With that IP address, it will go to a config template and modify it based on that IP (ie. if it is IP.100 then hostname would be Sunstone100).
-          Then it will push the configuration to the relevant IP/Sunstone.
Do we have details on how/if this can be achieved?
1 ACCEPTED SOLUTION
khgrant
VMS has reactive fastmap code that does this
4 REPLIES 4
khgrant
khgrant
We need to work with config drive not dhcp from Openstack dans mass
Therefore ip address is passed by nso In config drive and nso rely on VM deployed to move on with the service deployment i.e configure sunstone with day 1
khgrant
yep. I already use config drive for ip assignment. let us talk then next week. i am looking for practical implementation to make it work in the lab
khgrant
All,  my customer is looking at the same scenario…Is there any update on how to make this work?
Create
Recognize Your Peers
Content for Community-Ad
