amarcandalli
Beginner
Setting Timeout for CLI-Extension app command execution
Hi all,
I'm trying to develop a CLI-Extension application which includes some custom show commands.
It works fine if the server responds in less than 5 seconds. If it takes more (which is likely in my scenario) I get a "No Response from application." from the device. The following debug onep output shows that there is a default 5 seconds timeout.
Is there a way to change this timeout (via the device CLI or the onepk API)? Or is there another way to get that same result?
Thank you in advance.
Alessandro
.Jun 28 00:06:37.710: [info][tid: 116][ONEP][CLI]: Sending Show command <?xml version="1.0"?>
<NISApp xmlns="http://www.mycompany.it/NISApp:0.1"><exec><exec_show_nis><show/><nis/></exec_show_nis></exec></NISApp>
pid 116 Exec [fetch_obj_exec_af:2607]
.Jun 28 00:06:37.711: [info][tid: 116][ONEP][CLI]: Waiting for timed events [fetch_obj_exec_af:2621]
.Jun 28 00:06:37.711: [info][tid: 146] [session id: 2787] [ONEP][CLI]: Network Handler <?xml version="1.0"?>
Empty 2 [network_app_exec_handler:1124]
.Jun 28 00:06:38.711: [info][tid: 116][ONEP][CLI]:
No Response, Waiting 5 Seconds [fetch_obj_exec_af:2625]
.Jun 28 00:06:38.711: [info][tid: 116][ONEP][CLI]: Waiting for timed events [fetch_obj_exec_af:2621]
.Jun 28 00:06:39.711: [info][tid: 116][ONEP][CLI]:
No Response, Waiting 4 Seconds [fetch_obj_exec_af:2625]
.Jun 28 00:06:39.711: [info][tid: 116][ONEP][CLI]: Waiting for timed events [fetch_obj_exec_af:2621]
.Jun 28 00:06:40.711: [info][tid: 116][ONEP][CLI]:
No Response, Waiting 3 Seconds [fetch_obj_exec_af:2625]
.Jun 28 00:06:40.711: [info][tid: 116][ONEP][CLI]: Waiting for timed events [fetch_obj_exec_af:2621]
.Jun 28 00:06:41.711: [info][tid: 116][ONEP][CLI]:
No Response, Waiting 2 Seconds [fetch_obj_exec_af:2625]
.Jun 28 00:06:41.711: [info][tid: 116][ONEP][CLI]: Waiting for timed events [fetch_obj_exec_af:2621]
.Jun 28 00:06:42.711: [info][tid: 116][ONEP][CLI]:
No Response, Waiting 1 Seconds [fetch_obj_exec_af:2625]
.Jun 28 00:06:42.711: [info][tid: 116][ONEP][CLI]: Waiting for timed events [fetch_obj_exec_af:2621]
IOSv-1#
.Jun 28 00:06:43.711: [info][tid: 116][ONEP][CLI]:
No Response, Waiting 0 Seconds [fetch_obj_exec_af:2625]
.Jun 28 00:06:43.979: [146] [ONEP][CLI]:
ApplManagedData_setShowDataIDL_AL:setShowData[<?xml version="1.0"?>
] set to Error retrieving data from NIS session_handle[2787]
[ApplManagedData_setShowDataIDL_AL:236]
.Jun 28 00:06:43.980: [146] [ONEP][CLI]: Message name <?xml version="1.0"?>
, val Error retrieving data from NIS, pid -1, name Exec [onep_amd_exec_data_output_shim:134]
.Jun 28 00:06:43.980: [146] [ONEP][CLI]: Cant send message -1 <Exec> [onep_amd_exec_data_output_shim:140]
2 REPLIES 2
Joe Clarke
Hall of Fame Cisco Employee
Unfortunately, this timer is hardcoded to be five seconds.  I don't immediately see a way to get around this.  However, I will file an enhancement request to allow this timer to be configured.
Thanks for your reply Joseph.
I hope to see this enhancement soon in the upcoming releases.
Content for Community-Ad
