223
khgrant
SNMP trap for HA
Hi team,
I have a question regarding SNMP trap.
Can NSO system send the SNMP trap at the HA slave failure timing?
In my test when the Master fails (down), SNMP trap will be sent by new master NSO.
However when the Slave NSO fails, no SNMP trap will be sent.
Is there any way/config to enable the SNMP trap at the Slave NSO failure?
Gaku
7 REPLIES 7
khgrant
If it fails, then it probably  (or at least possibly)  isn’t able to do anything.
Cheers,
KJ.
khgrant
Hi KJ,
Thanks for your comment.
So for in case of Slave Failure, should we track the Slave NSO by some other system?
Gaku
khgrant
I'm confused here.
Which traps do you see. AFAIK no traps are ever sent by NSO HA code.
NSO generates SNMP traps when NSO alarms are created. The list of alarm types can be found under:
$NCS_DIR/src/ncs/yang/tailf-ncs-alarms.yang
/klacke
khgrant
Ahh, beautiful. So 3 different alarms in tailf-hcc-alarms.yang
   identity node-failure {
     base hcc-alarm;
     description
       "The node lost HA connection with its master";
   identity device-node-failure {
     base hcc-alarm;
     description
       "A service node noticed one of its device nodes lost
   identity bgp-failure {
     base hcc-alarm;
     description
       "A service node noticed it lost its BGP prefix path to
        its master";
khgrant
Hi Klacke,
Those 2 alarms(identity node-failure, identity device-node-failure) are sent by New-Master (original slave), when their original master is gone, correct?
khgrant
Checking the code:
I see one alarm getting created when there has been a fail over. I.e when a slave goes to master mode.
Type: node-failure
Text:
  "HA connection lost. '" + localNode +
   "' transitioning to HA MASTER role. " +
   "When the problem has been fixed, "+
"role-override the old MASTER to SLAVE to "+
   "prevent config loss, then role-revert all nodes. "+
   "This will clear the alarm.";
The other one device-node-failure you can  ignore unless you're using clustering and ha device nodes which is .. well ... very complicated and involved.
/klacke
khgrant
Hi Klacke,
Thank you very much!!
Gaku
Create
Recognize Your Peers
Content for Community-Ad
