Tail-F HCC Package for NCS-3.3.2
Installing Tail-f HCC package 3.3 gives below error on NCS-3.3.2  .Could you please share the Tail-F HCC Package for NCS-3.3.2
admin@ncs> show packages package
packages package tailf-hcc
package-version 3.0.9
description     "NED package for Tail-f HA Cluster Control Interface"
ncs-min-version [ 3.0 3.1 3.2.1.2 3.2.2 3.3 ]
directory       /var/opt/ncs/state/packages-in-use/1/tailf-hcc
templates       [  ]
component tcmCmdDp
  callback java-class-name [ com.tailf.ns.tcm.tcmCmdDp ]
component tcmDp
  callback java-class-name [ com.tailf.ns.tcm.tcmDp ]
component tcm
  application java-class-name com.tailf.ns.tcm.tcmApp
  application start-phase phase2
component tailf-hcc
  ned generic java-class-name com.tailf.packages.ned.tailfHcc.HccNed
  ned device vendor Tail-f
build-info date "2014-10-20 23:01:28"
build-info file ncs-3.2.2-tailf-hcc-3.0.9_d8b37ad.tar.gz
build-info arch darwin.x86_64
build-info java "compiled Java class data, version 51.0"
build-info package name tailf-hcc
build-info package version 3.0.9_d8b37ad
build-info package ref origin/lmanor/tr16677_2
build-info package sha1 d8b37ad
build-info ncs version 3.2.2
build-info ncs sha1 ""
build-info dev-support version 0.96
build-info dev-support branch dag/sed-on-mac
build-info dev-support sha1 61410a0
oper-status file-load-error
oper-status error-info "[ha-bgp-master.xml:10 Unknown namespace: 'http://tail-f.com/ned/quagga-bgp'], [ha-bgp-slave.xml:10 Unknown namespace: 'http://tail-f.com/ned/quagga-bgp'], [ha-bgp-none.xml:10 Unknown namespace: 'http://tail-f.com/ned/quagga-bgp']"
[ok][2015-06-03 14:48:32]
admin@ncs> exit
[root@localhost packages]# ls
ncs-3.3-tailf-hcc-3.0.9.tar.gz
Everyone's tags (6)
1 ACCEPTED SOLUTION
Highlighted
Re: Tail-F HCC Package for NCS-3.3.2
Did you try to reload package after removing template?
7 REPLIES 7
Highlighted
You need quagga-bgp package also.You need quagga-bgp package also.
Highlighted
This is a HA setup in L2 mode, not running quagga bgp package. Hence currently having the Tail-f HCC package should suffice.
Please add if missed any.
Highlighted
Right if you don¹t need BGP Anycast support then simply delete the templates.
Highlighted
I removed the templates and installed the packages, but still see the below error.
[root@nso-172-69 templates]# pwd
/var/opt/ncs/state/packages-in-use.cur/1/tailf-hcc/templates
[root@nso-172-69 templates]# ls
[root@nso-172-69 templates]# ncs_cli -u admin
admin connected from 10.156.49.88 using ssh on nso-172-69
admin@ncs> request packages reload
reload-result {
    package tailf-hcc
    result false
    info [ha-bgp-master.xml:10 Unknown namespace: 'http://tail-f.com/ned/quagga-bgp'], [ha-bgp-slave.xml:10 Unknown namespace: 'http://tail-f.com/ned/quagga-bgp'], [ha-bgp-none.xml:10 Unknown namespace: 'http://tail-f.com/ned/quagga-bgp']
[ok][2015-06-03 15:28:05]
templates       [  ]
component tcmCmdDp
component tcmDp
component tcm
component tailf-hcc
[ok][2015-06-03 15:28:10]
admin@ncs>
Highlighted
It would appear from the error below, that you still have the templates in place.
Highlighted
Highlighted
Yes, I was changing the sim link path. Deleting the templates in packages and reloading worked.
