Highlighted
Template Application Issue: NCS-HA using BGP Quagga
Hello NSO Team
We are facing a weird issue, where the template-to-be-applied is not in sync with the HA status at NCS. We have two devices in the same AS, but not connected directly to each other. We call them NSO-1 (Master) and NSO-2 (Slave). Diagram attached for reference.
When we shutdown the NCS process at master, the slave node will become the new ‘Master’
At new ‘Master’ (Previously slave)
admin@ncs% request ha commands status
status LAB-NFV-NSO-2[master]
[ok][2016-08-22 19:48:40]
However, when we telnet to the quagga device to see the applied template, we see this-
[root@LAB-NFV-NSO-2 state]# telnet 10.255.22.6 2605
Trying 10.255.22.6...
Connected to 10.255.22.6.
Escape character is '^]'.
Hello, this is Quagga (version 0.99.22.4).
Copyright 1996-2005 Kunihiro Ishiguro, et al.
User Access Verification
Password:
SLAVE>
SLAVE> en
SLAVE#
Instead of seeing the template ‘failover-master’ applied to the new ‘master’ (previously slave).
When we check the ncs-java-vm.log to see the process beneath, we see this-
<DEBUG> 22-Aug-2016::19:48:36.791 BgpAnycast Timer-0: - Querying BGP Prefix result:
BGP routing table entry for 10.255.22.8/32
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Advertised to non peer-group peers:
10.255.22.5
Local
0.0.0.0 from 0.0.0.0 (10.255.11.21)
Origin IGP, metric 0, localpref 100, weight 32768, valid, sourced, local, best
Last update: Fri Aug 19 00:21:10 2016
SLAVE#
<DEBUG> 22-Aug-2016::19:48:36.791 Cluster Timer-0: - UpdateLocalNode - beSlave
<ERROR> 22-Aug-2016::19:48:36.792 Ha Timer-0: - failed to call HA
Exception
<DEBUG> 22-Aug-2016::19:48:40.685 Cluster Timer-0: - UpdateLocalNode – beMaster
The BGP is now showing only one path for the prefix (as expected). But the following two messages are suspicious. The last message is to declare itself as a master, which is failed to reflect at the quagga device in applying the template.
Also, if the HA mode is deactivated in the master, will the slave recognize itself as ‘master’ or ‘none’? In our testing, the ‘slave’ node always goes to ‘none’ if the HA is deactivated at the acting ‘master’.
Above all, it would be very helpful if you can let us know how to find out the reason behind ‘configuration data base locked’ error, and to unlock it.
Please let me know if you need any more information from our setup to help us solve this situation.
Other outputs that may help
admin@ncs% show ha
token cisco123;
local-user admin;
bgp {
anycast-prefix   10.255.22.8/32;
anycast-path-min 1;
member LAB-NFV-NSO-1 {
address         10.255.22.2;
default-ha-role master;
cluster-manager true;
quagga-device   srdm-quagga;
member LAB-NFV-NSO-2 {
address         10.255.22.6;
default-ha-role slave;
failover-master true;
relay-name      LAB-NFV-NSO-1;
quagga-device   srdm-quagga2;
[ok][2016-08-22 20:04:42]
Thank you very much.
6 REPLIES 6
Highlighted
Re: Template Application Issue: NCS-HA using BGP Quagga
Hi Krishna,
Not sure what version are you using. We found similar behaviour with VMS 1.x (NSO 3.x) and filled couple of defects (like CSCuu90400), but AFAIK nothing got resolved….
BR,
Bostjan
Highlighted
Hi Bostjan,
We are on NCS 4.1 and tailf-hcc package version 4.1 as well.
Vineet
Highlighted
Hello Bastjan
Can you give us the list of CDETS ticket, to check on the what are the defect you experienced so far ?
Highlighted
Hi Krishna and Linshu,
Just out of curiosity, could you share template setting (show run devices template)?
Best regards,
Hiro
Highlighted
Hello Hiro –san
Here it is
admin@ncs# show running-config devices template
devices template hcc-failover-master
config
  quagga-bgp:hostname FAILOVER-MASTER
  quagga-bgp:route-map SET-AS-PATH 10
   set as-path prepend as-container as-number 65001
devices template hcc-master
config
  quagga-bgp:hostname MASTER
   set as-path prepend as-container as-number 65001,65002
devices template hcc-none
config
  quagga-bgp:hostname NONE
   set as-path prepend as-container as-number 65001,65002,65003,65004
devices template hcc-slave
config
  quagga-bgp:hostname SLAVE
Highlighted
Hello Linshu,
Thank you for sharing config.
The template looks good to me.
Maybe that’s a bug then.
I will let other experts comment.
Best regards,
Hiro
Content for Community-Ad
Cisco Community April 2020 Spotlight Award Winners
