Cisco Community Designated VIP Class of 2020
253
Highlighted
TLS ReconnectTimer problem
There seems to be a problem related to the ReconnectTimer. For a 2911 router (see below for version) we have experienced TLS disconnect problems. When trying to isolate and maybe to circumvent the problem, we have activated the reconnect timer functionality as suggested.
We are now experiencing a problem where a TLS session remains stuck in the Authenticated state:
R1#show onep session all
ID         Username State            ReconnectTimer ConnectTime                 ApplicationName
7250       cisco    Authenticated    60             Wed Aug 27 22:05:51.608     test.app
R1#
The onep application itself is terminated (and hence the TCP connection to the router is also terminated), but on the router side the session is not timed out and cleaned up, as expected.
The reconnect functionality has now made the situation more difficult:
  • the router keeps the state associated with the session
  • the onep application can not be restarted with the same name
  • changing the application name allows a new connection to be established, but dpss functionality is blocked due to the state kept by the router for the stuck session
It seems like the ReconnectTimer is stuck, as the state has not transitioned to the Connected state. Might that be the case?
Best regards
Viktor
Everyone's tags (1)
1 REPLY 1
Re: TLS ReconnectTimer problem
Version:
R1#show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(2)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 26-Mar-14 14:14 by prod_rel_team
<cut>
R1#show onep status
Status: enabled by: Config
Version: 1.2.0
Transport: tls; Status: running; Port: 15002; localcert: TP-self-signed-2336861257; client cert validation disabled
Certificate Fingerprint SHA1: 735DD3F7 45B61A68 D49E30B3 ACC8B17A 207620C3
Transport: tipc; Status: disabled
Session Max Limit: 10
CPU Interval: 0 seconds
CPU Falling Threshold: 0%
CPU Rising Threshold: 0%
History Buffer: Enabled
History Buffer Purge: Oldest
History Buffer Size: 32768 bytes
History Syslog: Disabled
History Archived Session: 5
History Max Archive: 16
Trace buffer debugging level is info
Service Set: Base              State: Enabled    Version 1.2.0
Service Set: Vty                State: Disabled    Version 0.1.0
Service Set: Mediatrace        State: Disabled    Version 1.0.0
R1#
Best regards
Viktor
Content for Community-Ad
FusionCharts will render here
