khgrant
Typical port numbers used by NSO and ESC
Hi All,
For a LGI Business Services  RFP I'm looking for a document outlining the typical port usage by NSO/ESC.
  1. E.g.:
Admin Interface: TCP/2024
SSH to device: TCP/22
Webportal: TCP/433
  1. etc.
Do we have such a thing?
Met vriendelijke groet / With kind regard,
Dirk-Jan van Helmond
1 ACCEPTED SOLUTION
khgrant
Hi Dirk Jan,
I went through ncs.conf and its man page for you
Here are the ports that where NSO is listening by default
Webui http: 8080
Netconf Northbound over ssh: 2022
Port for Internal process communication:4569 (it is listening on 127.0.0.1, so this is not externally reachable, unless you configure it differently)
Then NSO can be configured to listen to other ports but these are by default disabled, they are also all configurable.
Webui https:8088
Netconf northbound over tcp:2023
Neconf cli via ssh: 2024
Used by slave to listen for connections from master in HA case: 4570
Stefano
5 REPLIES 5
khgrant
Hi Dirk-Jan,
All the NSO ports being used are configurable and the current ones being used can be inspected in the “ncs.conf” file.
You could also do:
“man ncs.conf”
For more details.
Bilal.
khgrant
Hi Dirk Jan,
Webui http: 8080
Webui https:8088
Stefano
khgrant
Thanks Stefano!
khgrant
Additionally, as it may not be obvious:
NSO talks to ESC via netconf on port 830
JA
khgrant
Hi Julie Ann,
I listed only the ports where NSO listens, the ports where it opens connections are very very many, and dependent on what it is doing/ ssh/telnet/http/syslog/snmp/netconf etc. etc. These are dependent on the system that is listening at the other end.
Stefano
Content for Community-Ad
