khgrant
Using Netconf Console
I seem to be in a loop here – I wanted to look at netconf using the netconf console and I installed python paramiko but netconf console is still complaining:
gmp@lattice:~/ncs-staros$ netconf-console --hello
You must install the python ssh implementation paramiko
in order to use ssh.
root@lattice:~# pip install paramiko
Requirement already satisfied (use --upgrade to upgrade): paramiko in /usr/local/lib/python2.7/dist-packages
Cleaning up...
root@lattice:~# pip install paramiko --upgrade
Requirement already up-to-date: paramiko in /usr/local/lib/python2.7/dist-packages
Cleaning up...
root@lattice:~#
1 ACCEPTED SOLUTION
khgrant
This is just saying there is a problem with your Python environment.
Maybe you have several Pythons installed, and installed Paramiko in a one that's not first on the path when you run netconf-console? Once you got your Python environment in order so that you can import paramiko, netconf-console should be good to go as well:
$ python
Python 2.7.6 (default, Sep  9 2014, 15:04:36)
[GCC 4.2.1 Compatible Apple LLVM 6.0 (clang-600.0.39)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import paramiko
2 REPLIES 2
khgrant
$ python
>>> import paramiko
Hello, I am in the same loop :(
I have imported the paramiko module within Python3.6, but when I attempt to use the netconf-console, the output still remains: "You must install the python ssh implementation paramiko in order to use ssh."
May someone kindly help me?
Thanks in advance
Content for Community-Ad
