addPhone vendorConfig AXL for cisco telepresence sx20 using python/Zeep
lp.descamps
I'm trying to create a phone using python/zeep but i'm stuck for Product Specific Configuration Layout which is the vendorConfig.
How would you create the RoomName?
lp.descamps
here is the script I have been using
script
using the python module lxml
sample of the code
xmlstring = '<items>' \
'<webAccess>2</webAccess>' \
'</items>'
tree = ET.fromstring(xmlstring)
client.addPhone(phone=
        'vendorConfig': tree
dstaudt
The value you'll send it to vendorConfig will be an XML string comprised of the settings you want to control.  To get the format for a specific device (I assume the RoomName is one of those elements), one way is to create the device using the CUCM admin UI setting the variable as desired, and then use something like soapUI to perform <getPhone> - you can them examine the <vendorConfig> element as a template...
lp.descamps
script
sample of the code
'</items>'
Mike Hagans
Have you upgraded to 12.5 and if so, having issues with vendorConfig?
