addSNMPUser with axl 11.5
peteryun
Getting 500 internal error for addSNMPUser.  Anybody had a successful response?
2018-03-19 19:01:04,151 ucapi.cucmapi.CUCMAPI :81 - _send() - DEBUG receive 500 Internal Server Error
  X-Frame-Options: SAMEORIGIN
  Strict-Transport-Security: max-age=31536000; includeSubdomains
  Content-Type: text/xml;charset=UTF-8
  Content-Length: 371
  Date: Mon, 19 Mar 2018 19:04:17 GMT
  Connection: close
  Server:
  Body:
<?xml version="1.0" ?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
    <soapenv:Body>
        <soapenv:Fault>
            <faultcode>soapenv:Server</faultcode>
            <faultstring/>
            <detail>
                <axlError>
                    <axlcode>-1</axlcode>
                    <axlmessage/>
                    <request>addSNMPUser</request>
                </axlError>
            </detail>
        </soapenv:Fault>
    </soapenv:Body>
</soapenv:Envelope>
dstaudt
I could only get this request to work if I specified a list of hosts:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/11.5">
  <soapenv:Header/>
  <soapenv:Body>
      <ns:addSNMPUser>
        <user>
              <userName>testSnmpUser2</userName>
              <authRequired>true</authRequired>
              <authPassword>password</authPassword>
              <authProtocol>SHA</authProtocol>
              <privacyRequired>true</privacyRequired>
              <privacyPassword>password</privacyPassword>
              <privacyProtocol>AES128</privacyProtocol>
              <accessPrivilege>ReadOnly</accessPrivilege>
              <snmpEngineID>localSnmpID</snmpEngineID>
              <ArrayOfHosts>
                  <item>192.168.0.1</item>
              </ArrayOfHosts>
        </user>
      </ns:addSNMPUser>
  </soapenv:Body>
</soapenv:Envelope>
Omitting <ArrayOfHosts> or including an empty list resulted in the 500 error you showed...can you confirm this behaviour (likely a defect?)
Thanks.  Looks like empty ArrayOfHosts will do as well.  So, will go with that for now.
                <ArrayOfHosts>
                    <item/>
                </ArrayOfHosts>
