AXLError on CUCM 10.5 never thrown
mathias.tonn
i have built the Webservice client with Java 1.7 (JAX-WS). The namespace for the AXLError class is set to "http://www.cisco.com/AXL/API/10.5". This is defind in the AXL Schema file.
When i call a function on the client with dummy parameters to test the AXLError, i never get an AXLError. It throws always a SOAPFaultException.
The analysis of the result is showing no namespaces for the detail section. So JAX-B never maps the fault to the correct object class.
Is that an error ?
Example:
Input:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/10.5">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:getUser sequence="1">
         <userid>asdfg</userid>
      </ns:getUser>
   </soapenv:Body>
</soapenv:Envelope>
Return:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
   <soapenv:Body>
      <soapenv:Fault>
         <faultcode>soapenv:Server</faultcode>
         <faultstring>Item not valid: The specified User was not found</faultstring>
         <detail>
            <axlError>
               <axlcode>5007</axlcode>
               <axlmessage>Item not valid: The specified User was not found</axlmessage>
               <request>getUser</request>
            </axlError>
         </detail>
      </soapenv:Fault>
   </soapenv:Body>
</soapenv:Envelope>
My solution is writing a SOAPMessageHandler which corrects the namespaces on all AXLErrors.
class CiscoAXLErrorHandler implements SOAPHandler<SOAPMessageContext> {
    public CiscoAXLErrorHandler() {
    @Override
    public Set<QName> getHeaders() {
        return null;
    @Override
    public boolean handleMessage(SOAPMessageContext context) {
        //ntohing to do
        return true;
    @Override
    public boolean handleFault(SOAPMessageContext context) {
        //find AXLError in SoapFaultDetail...
        try {
            SOAPMessage soapMsg = context.getMessage();
            SOAPEnvelope env = soapMsg.getSOAPPart().getEnvelope();
            env.addNamespaceDeclaration("ns1", "http://www.cisco.com/AXL/API/10.5");
            Node n = soapMsg.getSOAPBody().getFault().getDetail().getFirstChild();
            if(n.getNodeName().equals("axlError")){
                SOAPElement newAXLError = soapMsg.getSOAPBody().getFault().getDetail().addChildElement(
                        env.createName("axlError", "ns1", "http://www.cisco.com/AXL/API/10.5"));
                soapMsg.getSOAPBody().getFault().getDetail().removeChild(n);
                NodeList nl = n.getChildNodes();
                for(int i =0; i<nl.getLength();i++){
                    SOAPElement child = newAXLError.addChildElement(nl.item(i).getNodeName());
                    child.setTextContent(nl.item(i).getTextContent());
                soapMsg.saveChanges();
                ByteArrayOutputStream out = new ByteArrayOutputStream();
                soapMsg.writeTo(out);
                String xml = new String(out.toByteArray());
                out.close();
                Logger.getLogger(CiscoAXLErrorHandler.class.getName()).log(Level.INFO, "######################\r\n"
                        + xml +"\r\n"
        } catch (SOAPException ex) {
            Logger.getLogger(CiscoAXLErrorHandler.class.getName()).log(Level.SEVERE, null, ex);
        } catch (IOException ex) {
        return true;
    @Override
    public void close(MessageContext context) {
        //nothing to clean up
Best regards
Mathias
0 Replies 0
