Walkthrough Wednesdays
492
Daniov1
Beginner
CUCM 12.5 AXL
I am trying to create a new line using addLine (POST API) , one of the paramenter is enterprise alternate number.
When I create a new line i am using the following XML parameters:
<soapenv:Envelopexmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"xmlns:ns="http://www.cisco.com/AXL/API/12.5">
  <soapenv:Header/>
  <soapenv:Body>
   <ns:addLine sequence="?">
    <line>
      <pattern>1590000</pattern>
      <useEnterpriseAltNum>true</useEnterpriseAltNum>
      <enterpriseAltNum>
      <numMask>XXXXXXX</numMask>
      <isUrgent>false</isUrgent>
      <addLocalRoutePartition>true</addLocalRoutePartition>
      <routePartition uuid="?">Global Learned Enterprise Numbers</routePartition>
      <advertiseGloballyIls>true</advertiseGloballyIls>
      </enterpriseAltNum>
     </line>
    </ns:addLine>
   </soapenv:Body>
</soapenv:Envelope>
The line was created successfully but without enterprise alternate number configuration.
I configured it menually and use getLine ,  I tried to use the returned value with addLine but enterprise alternate number was not configured.
Any suggest?
1 ACCEPTED SOLUTION
dstaudt
Looking at the schema doc, there is a small note that seems to indicate that the *AltNum elements are applicable only on update operations.  Perhaps due to some internal quirk, the line must first be created before an alt num can be defined for  it?
Can you try first adding the line, and then performing a second updateLine operation providing the *AltNum fields?
3 REPLIES 3
dstaudt
Thanks for your reply.
This is about addLine not addPhone.
Do you mean that I need to create first the line and then update it with *altNum field?
Thanks.
Yes, sorry...I've updated my original comment to reflect line vs phone
Content for Community-Ad
