Highlighted
Help, How start/stop a CUCM Service Using SOAPUI (12.5)
Hi guys,
I was trying to find a SOAP function that enabled me to stop a Service in any node.
I downloaded the AXL squema and I have found.
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/12.5">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:updateProcessNodeService sequence="?">
         <!--You have a CHOICE of the next 2 items at this level-->
         <uuid>?</uuid>
         <processNodeName uuid="?">?</processNodeName>
         <service>?</service>
         <!--Optional:-->
         <traceLevel>0</traceLevel>
         <!--Optional:-->
         <userCategories>0</userCategories>
         <!--Optional:-->
         <enable>false</enable>
         <!--Optional:-->
         <numFiles>250</numFiles>
         <!--Optional:-->
         <maxFileSize>1</maxFileSize>
      </ns:updateProcessNodeService>
   </soapenv:Body>
</soapenv:Envelope>
But that does not necessarily stop the process. Just disable or enable trace level.
For instance If I want to stop
Control Center -> Network Services
MIB2 Agent (select)
then start/stop
Thank you very much for your help.
Everyone's tags (4)
