listUcService call returns nothing
dkartio20
Running follow call against CUCM 10.5.2 server
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<SOAP-ENV:Header/>
<SOAP-ENV:Body>
     <axl:listUcService xmlns:axl="http://www.cisco.com/AXL/API/10.5" sequence="1">
          <searchCriteria>
               <name>%</name>
          </searchCriteria>
          <returnedTags>
               <name/>
               <serviceType/>
          </returnedTags>
     </axl:listUcService>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
And getting this return blank return
<?xml version='1.0' encoding='utf-8'?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
<soapenv:Body>
     <ns:listUcServiceResponse xmlns:ns="http://www.cisco.com/AXL/API/10.5">
          <return/>
     </ns:listUcServiceResponse>
</soapenv:Body>
</soapenv:Envelope>
I can run a getUcService call for a service named "clacup01a", and it works fine and returns the following:
<soapenv:Body>
<ns:getUcServiceResponse xmlns:ns="http://www.cisco.com/AXL/API/10.5">
     <return>
          <ucService uuid="{SOME UUID}">
          <serviceType>IM and Presence</serviceType>
          <productType>Unified CM (IM and Presence)</productType>
          <name>clacup01a</name>
          </ucService>
     </return>
</ns:getUcServiceResponse>
</soapenv:Body>
</soapenv:Envelope>
Anyone have any ideas why nothing is returned by the list call, when there are services available to return???
npetrele
Perhaps it has something to do with the way you're using the namespace?  Try this - it works for me.
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/10.5">
<SOAP-ENV:Header/>
<SOAP-ENV:Body>
          <searchCriteria>
               <name>%</name>
          </searchCriteria>
          <returnedTags>
               <name/>
               <serviceType/>
          </returnedTags>
</SOAP-ENV:Body>
Technically, the axl namespace is redundant if you do the above, so here's an example without it.
<SOAP-ENV:Header/>
<SOAP-ENV:Body>
     <ns:listUcService sequence="1">
          <searchCriteria>
               <name>%</name>
          </searchCriteria>
          <returnedTags>
               <name/>
               <serviceType/>
          </returnedTags>
     </ns:listUcService>
</SOAP-ENV:Body>
