Mediasense reporting not active recording to API
wsolanovi
Beginner
Beginner
Hello Folks,
I have a customer with two node setup of MediaSense 10.5 . Customer is using the MS API to add custom tags to active recordings. The problem is that sometimes MediaSense is telling the API that there are no active calls on the user's IP phone and we now there is an active call. As a result of MS not responding with the SessionID the process of adding the custom tag fails; by any chance you know what could be causing MS to fail to retrieve the sessionID for some calls?
We are using the getSessions method with parameters sessionStartDate, deviceRef (equals), sessionState (active).
Any help will be really appreciated
5 REPLIES 5
Anil Verma
Contributor
Contributor
There could be a timing issue. MediaSense will show the recording only after the request has been received by MediaSense. It could also be an issue with the HA scenrios, are you checking for the Primary server, and potentially the recording is on the secondary. There might be timing issues there too.
Thank you Anil. We have a 15 seconds delay before the time that we know the UCCX agent answered the call until the time the API asks MS for the recording, if is taking longer that 15 seconds for MS to acknowledge is really unlikely IMO.
For the HA part we enabled Event Forwarding which should allow us to only contact one server and that server should be aware of the events happening in the HA pair from what we understand on the documentation
Can we have a quick webex for debugging this issue? I am in IST time zone.
Sure we can! we just need to coordinate time. We can also capture the traces from the MS server and the ones from our proxy API server which logs the messages that are sent/receive from/to MS
Let's plan the meeting on 10th Nov, Thursday. We are available from 11:00 am IST to 7:00 pm IST.
