"ATS failed system trust. error - code: -1200"
Good Day Experts,
I am trying to integrate my swift based IOS application with a Cisco Unified Communications Manager version 11.5 using standard RISPORT70 API:
https://developer.cisco.com/docs/sxml/#!risport70-api-reference/selectcmdevice
to get some responses generated off of the API Call.
I make the following call:
https://<server IP>:8443/realtimeservice2/services/RISService70?wsdl
with its corresponding SOAP envelop in the body but get a ATS failed system trust. error - code: -1200
The api call works without SSL Cert Verification on Postman but does not work on the actual app.
I have tried:
  1. Got an Internal PKI Signed certificate certificate on the Cisco Server and added the root, intermediate and the server cert on the local keychain.
  2. Tried to update the the info.plist with the following parameter:
    • Allow Arbitrary Loads for Media
    • Allow Arbitrary Loads in web content
    • Added Exception Domains
    • Send a SOAP Enveloped Body.
    • Send this via Xcode to any Cisco Call Manager
Errors:
2019-10-09 16:54:56.336902-0400 APP[3556:172438] ATS failed system trust2019-10-09 16:54:56.337008-0400 APP[3556:172438] Connection 1: system TLS Trust evaluation failed(-9802)
2019-10-09 16:54:56.337125-0400 APP[3556:172438] Connection 1: TLS Trust encountered error 3:-9802
2019-10-09 16:54:56.337202-0400 APP[3556:172438] Connection 1: encountered error(3:-9802)
2019-10-09 16:54:56.340683-0400 APP[3556:172438] Task <2F074FBA-C54B-4972-B269-1B3EE5919344>.<1> HTTP load failed, 0/0 bytes (error code: -1200 [3:-9802])
Optional(Error Domain=NSURLErrorDomain Code=-1200 "An SSL error has occurred and a secure connection to the server cannot be made." UserInfo={NSURLErrorFailingURLPeerTrustErrorKey=<SecTrustRef: 0x60000071a2e0>, NSLocalizedRecoverySuggestion=Would you like to connect to the server anyway?, _kCFStreamErrorDomainKey=3, _kCFStreamErrorCodeKey=-9802, NSErrorPeerCertificateChainKey=(
 Any help here will be much appreciated.
Himank Pande
#xcode #cisco-axl #swift #cucm #callmanager #certificate
thedd
Where is your application running?
I would say that the device dos not trust the certificate presented from CUCM.
