Reset Voicemail PIN using AXL
mike.patel
I'm new to Cisco AXL
Can you anyone point me to correct direction.
I'm trying to reset voicemail PIN and setting that user has to change PIN on next login.
Should I use CUCM end point that looks like https://CCMSERVERNAME:8443/axl/
and which soap message I need to use.
smiller1
Mike,
I'm assuming that you're using Unity for your voicemail.  You'll want to look at the CUPI documentation for that.  This article in particular covers Unity voicemail PINs: Cisco Unity Connection Provisioning Interface (CUPI) API -- User Password PIN Settings - DocWiki
smiller1
Mike,
