Starting with MediaSense Call Recording
Hi Everyone,
Hope you will be fine and enjoying your life. I recently started working in MedisSense API. I have gone through its documentation and Now I am actually turning to its Implementation. I want to record a call made to particular extension. For this I used this API call:
http://---.---.---.---:8440/ora/controlService/control/startRecording
And Body:
Header: Content-Type: application/json & mentioned JSESSIONID too.
Body:
{"requestParameters": {
"deviceRef": "42021",
"mediaStreams": [
"mediaType": "AUDIO"
After making this API call, I make call to extension mentioned in body of this request that is '42021'.
I have tried this using poster. I didn't get any response. I want to know that this is how we record a dialogue ? where the recorded file is saved ? I need sample Application from which I may take help. The one uploaded by cisco is not sufficient for me. Ant tutorial, sample Application and help will be highly appreciated.
jwolfeld
This is a common misunderstanding.  The startRecord API is unfortunately named; it's probably NOT what you want to use.  In fact it is rarely used by anyone.
There are two kinds of Direct recording in MediaSense: Direct Inbound and Direct Outbound.  These are described in the SRND and the User's Guide.  With Direct Inbound, you configure a trunk from CUCM to MediaSense and assign it a dial pattern.  Then from any CUCM phone, you dial that pattern.  MediaSense answers, and simply records whatever you say.  You will be able to see the recording in the Search and Play application, but it is NOT the recording of a 2-way conversation.
Direct Outbound is exactly the same thing, except that MediaSense calls the phone rather than the phone calling MediaSense.  They way you get MediaSense to call the phone is by issuing the startRecord API.  Again, this does NOT record a 2-way conversation; it only records what the phone user speaks into the phone.  (And by the way, if the phone supports video, MediaSense will record the video as well.)
For your initial testing, you might want to try the Direct Inbound method described above.   But then you'll want to quickly move on to configuring CUCM recording profiles and other structures, and configure your phone to "always record".  (Make sure you are using a phone that supports media forking!).  Then you'll start capturing 2-way conversations.
10 Replies 10
jwolfeld
One more thing - the non-response from Poster.  That sounds like you did not take steps to accept the MediaSense certificate in your browser first.  This is described in the MediaSense Developer's Guide, under "Building your Application."
Yes, I added the certificate in java for using this API Programatically but didn't add certificate in browser but now I have added and I can make HTTPS requests from poster too.
Then I have the following questions:
1. StartRecording API is used just for outbound calls recording ? If yes then it means that outbound call recordings can be done by running this API call withour any configurations on MediaSense server as I have APIUser and make calls by this.
2. Will we have two recordings for each call, one for inbound and other for outbound ? Is this not possible to have single recording against each call containing both what phone user and agent speaks ?
Thanks for your assistance in making me things clear :-)
StartRecordingAPI is used for blog recordings. Per the MediaSense Developer Guide section on Mapping a Session to a Recording:
Several recordings are possible using the Cisco MediaSense platform:
Forked media from a Cisco IP Phone or Cisco Unified Border Element (CUBE) device. This recording has two audio channels.
Direct call to/from the Cisco MediaSense platform to any phone. This recording has one audio channel and one optional video
channel. These recordings are referred to as Blog recordings in this document
Forked media calls are retrieved using the Session API. Per the section Mapping a Media Stream to a Track:
A media stream refers to the packets going through an audio channel or video channel in a live or recorded session.
A track identifies each media stream and quantifies it with additional data such as participants, duration, startDate, and a trackNumber. Track
0 contains media streamed from the forking device, and Track 1 contains media streamed to the forking device. In a
sessionEvent , each track is associated with one participant.
dlender jwolf
I want to configure my MediaSense server for calls recordings. What steps I need to follow ? Or is there any document that may guide me regarding configuring my MediaSense server for call recordings ?
I am not aware of any guide documentation on how to configure Callmanager and MediaSense to record calls.
If you are a Cisco Partner you may wish to utilize the PDI Helpdesk to assist you in this configuration.
http://www.cisco.com/web/partners/tools/pdihd.html
See the MediaSense User Guide here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/mediasense/911/user_guide/CUMS_BK_M5B01864_00_ms-user-guide-911/CUMS_BK_M5B01864_00_ms-user-guide-911_chapter_011.html#CUMS_CN_I1F747F8_00
See Administer and Configure MediaSense.
dlender
Level 6
Level 6
Also your body is missing a '}'
http://-.-.-.-:8440/ora/controlService/control/startRecording<http://192.168.200.204:8440/ora/controlService/control/startRecording>
And Body:
Body:
"mediaStreams": [
yes, In my actual code it's all right. I didn't copy completely code here and missed a closing '}' brace.
