Bookmark
Subscribe
1148
Separate Directory Services But Same Duo?
heckyeahcool
I work on large campus, but my particular department has its own LDAP directory service and CAS server separate from the main campus – which uses AD DS, JSIG CAS, Shibboleth, and Duo. So, users in my department have a main campus network ID and and a “my department” network ID. Is it possible to implement the main campus Duo with my department’s CAS server LDAP users, i.e., by user mapping or some sort of directory sync, or CSV import into the Duo system?
Brian
Sure. Basically, our LDAP UIDs matched the campus directory’s UIDs.
heckyeahcool
Solved after working with main campus IT.
Hi Brian,
I’m glad you were able to solve this. Thank you for following up here to let the community know you found the answer. Would you mind sharing the solution here in case others have the same question?
