Tuan Nguyen
Beginner
2921 ISR router
Having question on ISR 2921 G2
If I installed SM-ES3G-16-P’s in my 2921, could they perform all the functions of a Metro Ethernet switch utilizing the data license of the router ?
1 REPLY 1
Alessio Andreoli
Contributor
Not all of them but most of. You will not have any issue in most of the layer 2 technologies. I would say that when the design will get more complex(e.g. SP scenario) this amazing module will highlight that is just a module. Good buying though.
Hope this helps
Alessio
