04-27-2008 11:00 PM
Hi All,
802.1ag defines and classifies MEP as 'Down MEP' and 'Up MEP' where as Y.1731 doesn't classify MEPs. How will be the implementation when a device supports both 802.1ag and Y.1731 standards? Can we assume the MEP in Y.1731 implementation always to be a 'Down MEP'?
Why have two different standard bodies defined separate standards for the same functionality ( CC, LT and LB)?
-Sriram K
05-05-2008 06:15 AM
mep-up -- Generates a trap when a new remote maintenance end point (MEP) has been discovered and learned by the device or when a change occurs in the port state of a previously discovered remote MEP.
mep-down -- Generates a trap when a device has lost connectivity with a remote MEP or when connectivity from a previously learned remote MEP is restored after interruption.
05-05-2008 07:31 AM
Thanks for your reply. I think I wasn't clear enough. By the terms "Up MEP" and "Down MEP", I meant the direction of the MEP and not the state. In cisco's terms Up MEP = Inward facing MEP(MAC Relay entity side transmission) and Down MEP = Outward facing MEP(wire side transmission).
