Access and trunk pseudowire with L2PT
Terry Pattinson
Hi all,
I've done extensive testing and I would like some confirmation regarding my conclusions:
1. rewrite ingress tag pop 1 symmetric has no effect on Layer 2 control frames (STP, CDP, etc).
2. access and trunk connections on each end of a pseudowire works fine (popping of tagged ingress data frames)
3. l2protocol tunneling is not supported (due to item 1 above)
I have the following topology - client A and client B are standard switches and SW01 and SW03 are ME3600s.
ClientA --> access int (vlan 10) --> SW01 --> Pseudowire --> SW03 --> dot1q trunk --> Client B
I observe the following log messages on ClientA:
*Oct 16 08:22:02.727: %SPANTREE-SP-7-RECV_1Q_NON_TRUNK: Received 802.1Q BPDU on non trunk TenGigabitEthernet2/2 VLAN10.
*Oct 16 08:22:02.727: %SPANTREE-SP-7-BLOCK_PORT_TYPE: Blocking TenGigabitEthernet2/2 on VLAN0010. Inconsistent port type.
And the following on ClientB:
*Oct 16 08:35:08.951: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on TenGigabitEthernet1/2 (1), with ClientA TenGigabitEthernet2/2 (10).
Configurations
Client A:
interface TenGigabitEthernet2/2
switchport
switchport access vlan 10
switchport mode access
SW01
interface TenGigabitEthernet0/1
switchport trunk native vlan 10
switchport trunk allowed vlan none
switchport mode trunk
service instance 10 ethernet
  encapsulation untagged
  l2protocol tunnel
  xconnect 192.1.0.3 10 encapsulation mpls
SW03
  encapsulation dot1q 10
  l2protocol tunnel
  xconnect 192.1.0.1 10 encapsulation mpls
ClientB
interface TenGigabitEthernet1/2
switchport
Adam Vitkovsky
Level 3
Level 3
Hi Terry,
Looks like the BPDU guard kicks in on Client-A putting the access port into errdis after receiving BPDU indicating a possible loop
So you might want to change the Client-A port to trunk with native VLAN 10
Oh and if possible do “l2protocol forward” instead of the Cisco proprietary “tunnel” even though in this case it doesn’t really matter.
adam
adam
