ASR901 vs ME3600X
2044418Puts
I've never worked with an ASR901 before and now I'm designing an MPLS network but with several budget constraints.
Basically what I need is 1 customer edge port and 2 MPLS ports to connect to an MPLS cloud. I would normally use an ME3600X for this, but, since the ASR901 is running the same software and also has enough ports available for lets say half the price, I was wondering if this would suffice too.
Can anyone tell me the noticable differences between those platforms?
Like:
MVPN Support.
Service Instances.
etc?..
The network is not TDM related or whatever. So basically I was just looking at the Ethernet version of this router (A901-6CZ-F-A).
Thanks!
Armand
petehaaswws
Hi Armand,
The IOS for ME3600X starting 15.2-2S  and above appears to have alot of overlapping features with the IOS on ASR901 series although I'm sure there are quite a few differences left still and the Feature Navigator will substantiate this.
Are you trying to terminate pseudowires on service instances?
Cheers
Peter
