01-15-2019 04:29 PM
I'm struggling with how to manage the asr920 remotely. I have a UNI S-port feeding connectivity to the unit. In this s port is a tag that contains a management VLAN. I've tried configuring a c-port, but I kind of figured it wouldn't work connecting that port to the management interface - which it doesn't. I don't have any other boxes I can connect to at this location. Is there a way to create a virtual interface on the unit and have it associated with a uni c port? Or am I going about this in the wrong manner?
08-27-2019 09:36 PM
Hi, for management you can use a Tacacs Server and configure to use it, also you can review the following document:
https://www.cisco.com/c/en/us/td/docs/routers/asr920/b_Chassis_Guide_asr920/mgmt-ethernet.pdf
Good Luck!
Regards!
09-13-2019 04:53 PM
Hi nwilson,
what you can do is to create a specific VRF for management and attach a loopback interface to it. Then redistribute that loopback into BGP.
There is a quick guide of how to implement L3VPN for your use case:
regards,
