Hi all,
we would like to use the ASR1006 as ATM aggregation router, the customers connect to the ASR to use E-VPN service
to connect to the main locations on ethernet backbone.
ATM VPLS Customer Vlan
CE1-------ASR------------PE1--------PE2-----------------------CE
ATM |
CEN---------|
The CE should tag the frames with two vlans (one management, one production).
I am planning to use xconnect on sub ATM interfaces to the VPLS on the backbone.
I have 2 issues:
1-the CE1 will tag the frames with a vlan that is different from the VPLS vlan. for example CE1 tag frame with vlan 2004 and xconnect to PE1 in VPLS vlan 4000 at PE2 it is again translated to 2004 but in the response the packet will be forwarded to PE1 with VLAN 4000 and then xconnect to ASR with vlan 4000 and sent in ATM to CE1.
2- is there a way to extract the management vlan from the ATM PVC?
The version of ASR is asr1000rp1-advipservicesk9.03.03.02.S.151-2.S2.bin
could you please advice?
Mounir
