CFM - Unable to get remote maintenance points learning
MTA
Greetings,
I am trying to establish CFM connectivity using emulation (CSR1000v).
I am running VPLS (Manual discovery) for end to end connectivity.
The topology in use is CE4 - PE2 - PE3 - CE6
Connectivity in place , what am not able to get the remote maintenance points learning so any idea would be appreciated.
Relevant configuration are below from PE2 perspective.
PE2#show version
Cisco IOS XE Software, Version 17.03.02
ethernet cfm ieee
ethernet cfm global
ethernet cfm traceroute cache
ethernet cfm alarm notification all
ethernet cfm domain SPCOR_DOMAIN level 7
service SRVC evc EVC1 vlan 20
mep mpid 170
continuity-check
mip auto-create
ethernet evc EVC1
oam protocol cfm domain SPCOR_DOMAIN
l2 vfi CONN manual EVC1
vpn id 20
bridge-domain 20
neighbor 10.1.100.3 encapsulation mpls
interface GigabitEthernet1
no ip address
negotiation auto
no mop enabled
no mop sysid
service instance 20 ethernet EVC1
encapsulation dot1q 20
bridge-domain 20
cfm mep domain SPCOR_DOMAIN mpid 170
cfm encapsulation dot1q 20
PE2#show mpls l2transport vc 20
Local intf     Local circuit              Dest address    VC ID      Status
VFI CONN       vfi                        10.1.100.3      20         UP
PE2#show ethernet cfm maintenance-points local
Local MEPs:
MPID Domain Name                                 Lvl   MacAddress     Type  CC
Ofld Domain Id                                   Dir   Port           Id
     MA Name                                           SrvcInst       Source
     EVC name
170  SPCOR_DOMAIN                                7     001e.f636.e6bf BD-V  Y
No   SPCOR_DOMAIN                                Up    Gi1            20
     SRVC                                              20             Static
     EVC1
Total Local MEPs: 1
Local MIPs: None
PE2#show ethernet cfm maintenance-points remote
PE2#ping ethernet mpid 170 domain SPCOR_DOMAIN service SRVC
Sending 5 Ethernet CFM loopback messages to 0000.0000.0000, timeout is 5 seconds:.
Mohammad
0 Replies 0
