CISCO ME-3400-24TS-A
anujkumar7971
ET-1-AUTHENTICATION_FAIL: This Switch may not have been manufactured by Cisco or with Cisco's authorization. This product may contain software that was copied in violation of Cisco's license terms. If your use of this product is the cause of a support issue, Cisco may deny operation of the product, support under your warranty or under a Cisco technical support program such as Smart net. Please contact Cisco's Technical Assistance Center for more information.
its repeating after every 5mint
can u somebody suggest about this problem
LaloRam
HI Anuj,
once I had that issue, I contacted TAC and they helped me with the RMA process. Im not fully sure that this box is still supported, but you can check with them.
regards,
LaloRam
HI Anuj,
regards,
