dfrenay_olabs
Beginner
Dot1q tunneling and security
I don't understand how to make to improve the security of dot1q tunneling. If the client makes some errors by example by disabling the spanning-tree on a vlan and he creates a loop between differents sites (L2VPN). What are the safety standards for Q-in-Q to protect the provider ?
Thank you for your help.
Regards.
David
0 REPLIES 0
