Ethernet link integrity in NCS 540
jigojar
 does cisco NCS 540 device supports the  Ethernet link integrity functionality?
5 Replies 5
helpcenterus
Hello @jigojar! yes, the Cisco NCS 540 device supports Ethernet link integrity functionality. This feature is commonly integrated into Cisco networking devices to ensure the reliability and stability of Ethernet connections.
Hi @helpcenterus ,
 Can you pls provide the config details for the link integrity?
Certainly, @jigojar ! Configuring Ethernet link integrity on a Cisco NCS 540 typically involves accessing the device's command-line interface (CLI). You can use the "interface" command followed by the specific Ethernet interface you want to configure. Within the interface configuration mode, use the "eth-link-integrity" command to enable link integrity monitoring. Additional parameters may be available depending on your specific requirements. Don't forget to save the configuration using the "write memory" command to ensure that changes persist after a reboot.
jigojar
Hi Guys,
 I dont find the eth-link-integrity command. can you pls help with the CLI?
int RP/0/RP0/CPU0:100.65.212.100(config)#int Te0/0/0/8
RP/0/RP0/CPU0:100.65.212.100(config-if)#ethernet?
ethernet ethernet-services
RP/0/RP0/CPU0:100.65.212.100(config-if)#eth?
Hello @jigojar ,
look at the Ethernet OAM config guide it may be something near to what you are looking for
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5xx/interfaces/24xx/b-interfaces-hardware-component-cg-24xx-ncs540/config-ethernet-oam.html
Hope to help
Giuseppe
