ME3800 HA
tbrumbaugh
I am running a pair of ME3800's but have one as a hot standby and have been copying the config over to it on a regular basis.  I would like to make it a active active or active standby HA pair,  is this possible?
joshuacmoore
If you are talking about something similar to a stack or VSS the answer is no.
If you are ok with doing a redundant configuration using STP, REP, first hop redundancy protocol or a routed solution to downstream switches this is possible.
joshuacmoore
