Monitoring ME 3400 QoS.
mjgarate
2 questions:
We have a ME 3400 con qos configured, we'd like to monitor the bw per class, we have two ways, one using the "show policy-map interface output/input" however the output is not showing the bps rate:
Switch#show policy-map interface output
FastEthernet0/1
Service-policy output: OUT
Class-map: VO (match-any)
0 packets
Match: qos-group 1
Priority
police cir 2000000 bc 62500
conform-action transmit
exceed-action drop
conform: 0 (packets) exceed: 0 (packets)
Output Queue:
Max queue-limit default threshold: 16
Tail Packets Drop: 0
Class-map: DCO (match-any)
1414 packets
Match: qos-group 2
Traffic Shaping
Average Rate Traffic Shaping
CIR 5000000 (bps)
Output Queue:
Max queue-limit default threshold: 48
Class-map: class-default (match-any)
3830 packets
Match: any
Output Queue:
Bandwidth 3000 (kbps)
Output Queue:
1. Is there a way to see the bps rate per class?
2. Using SNMP did not work also. Any help???
Thanks and regards
5 Replies 5
swaroop.potdar
Level 7
Level 7
12.2(35)SE, 12.2(25)SEG1 & SEG , 12.2(25)EX1 & EX These release for the ME3400 support Class-Based-QOS-MIB
HTH-Cheers,
Swaroop
Thanks Swaroop, however i'm confused because if we look the ios version supported by the MIB we could see the versions that you mention, but if we look for the MIBs supported by the IOS that MIB is not in the list.
http://www.cisco.com/en/US/products/ps6580/products_configuration_guide_chapter09186a0080773210.html
what is the correct information?
regards
Mario, I agree to what you have mentioned,but I believe the above list should be reliable, do give it a try and check.
HTH-Cheers,
Swaroop
i'd tried but is not working.
regards
-Mario
Can you try the CLI command as follows,
show policy-map interface [ specify interface id here or leave it] output/input.
for Eg:
show policy-map interface fa0/1 output.
HTH-Cheers,
Swaroop
