No EVC encapsulation configuration on 7613
jobg12345
I have to configure the EVC on 7613 with ES+20G.
But i can not configure it because there is no the encapsulation configuration on 7613.
So i check the relese12.2(SR) configuration note and then i know there is the encapsulation configuration on 7613.
I have used the 12.2(33)SRD4 version.
So can you teach me the WHY and HOW to configure it on 7613.
Thank you
rsimoni
what do you mean there is no encapsulation on 7613?
The config on 7613 does not differ from any other 7600 router.
The EVC configuration will be something like this:
Interface GigabitEthernetx/x
service instance 15 ethernet
  encapsulation dot1q 2000 second-dot1q 20
  rewrite ingress tag pop 2 symmetric
  bridge-domain 110
service instance 40 ethernet
  encapsulation dot1q 333
  rewrite ingress tag pop 1 symmetric
  bridge-domain 32 split-horizon
for more have a look at:
Cisco 7600 Series Ethernet Services Plus (ES+) and Ethernet Services Plus T (ES+T) Line Card Configuration Guide
Configuring Layer 1 and Layer 2 Features
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES40_config_guide/es40_chap4.html
Riccardo
Thank you for your help...
you are very kind
Thank you
