05-03-2005 11:17 PM
Hi..
If i use EWS QinQ tunneling and configure a tunnel port, how can i perform QoS on that port. I would like to rate limit it to say 2Mbps for example.
According to CCO document, any class-map related to layer 3 information will not work in tunnel port. If that is the case, how can i do the rate limiting.
Eng Wee
05-04-2005 08:26 PM
i tried the config below, but doesn't seem to work. Am i missing anything ?
mls qos
class-map match-all POLICE-L2VPN
match access-group name ALL-MAC
policy-map POLICE-L2VPN
class POLICE-L2VPN
police 1000000 256000 exceed-action drop
spanning-tree mode pvst
spanning-tree portfast default
spanning-tree portfast bpdufilter default
mac access-list extended ALL-MAC
permit any any
vlan dot1q tag native
interface FastEthernet0/30
switchport access vlan 30
switchport mode dot1q-tunnel
switchport nonegotiate
no ip address
load-interval 30
service-policy input POLICE-L2VPN
no cdp enable
spanning-tree bpdufilter enable
05-05-2005 11:15 PM
I'm not really sure if the mac acl is working, I haven't such an example in production. I use normally an IP acl.
Here is an example I used many times. It's working fine.
Example:
mls qos
class-map match-all C1
match access-group 100
policy-map Max2M
class C1
police 2000000 512000 exceed-action drop
switchport access vlan 10
switchport mode access
service-policy input Max2M
access-list 100 permit tcp any any
access-list 100 permit udp any any
I haven't a tunnel port, but this shouldn't be a problem. I hope this helps.
Cheers
Rene
05-06-2005 08:48 PM
According to TAC, mac acl is for non-IP traffic only, that explains why ip acl doesn't work in tunnelled ports. This is wat tac suggested. I haven't had a chance to try, will try it out when i get back from my leave. If anyone has the chance to try this out, do let me know the outcome
mac access-list extended l2
permit any any
ip access-list extended l3
permit ip any any
class-map L2-traffic
match access-group name l2
class-map L3-traffic
match access-group name l3
mls qos aggregate-policer Customer-1 10000000 13000 exceed-action drop
policy-map Customer-1-policy-ingress
class L2-traffic
police aggregate Customer-1
class L3-traffic
