04-26-2019 09:07 AM
I am a newbie to handle the cisco equipment. grateful if you would help to enlighten me how to handle the ME circuit relocation from cisco 2960x to cisco 3850x
Q1. any modification is required before the ME circuit relocation? if yes, which one and how to rectify it, any service impact on it
Q2. any tuning on the ethernetchannel setting on 3850X (or 2960X) side.
background info:
- there are two ME circuits, they are connected single 2960X in KLN and single 2960X in NT
- the ethernetchannel is configured on 2960X with LACP. both 2960X switches are normal
- cisco 2960X and 3850X is connected via access port
- There are two ethernet switches (cisco 3850X) in KLN, it is required to move the ME circuit to each cisco 3850X
A. below is 2960X config in KLN,
system mtu routing 1500
spanning-tree mode pvst
interface Port-channel1
description connect ME circuit in NT
switchport mode trunk
interface GigabitEthernet1/0/10
channel-group 1 mode active
interface GigabitEthernet1/0/12
description connect from 2960x to 3850 for vlan 50
switchport access vlan 50
switchport mode access
spanning-tree portfast
interface GigabitEthernet1/0/2
description connect from 2960x to 3850 for vlan 80
switchport access vlan 80
VTP setting is server
B. below is cisco 2960X config in NT
description connect ME in KLN
! ! there is no any setting under port channel
C. below is the cisco 3850x with stack config
spanning-tree mode rapid-pvst
! Pre-config ethernetchannel
interface TenGigabitEthernet3/0/10
description connect to ME circuit 1
shut
interface TenGigabitEthernet3/0/5
connect to cisco 2960x for vlan 50
interface TenGigabitEthernet4/0/10
description connect to ME circuit 2
shut
Solved! Go to Solution.
04-29-2019 05:26 AM - edited 04-29-2019 05:28 AM
Dear Jaderson Pessoa,
Thanks for your configuration.
Below is the ans for your question
"For what reason you have a connection between ME and 2960x in KLN?"
Ans: KLN is new site and some testing servers are connected in it. For some reason, the new 3850X shipment is delivery over half year. the temp 2960X is temp to install for it.
I have some questions would like to seek for your advice. grateful if you would enlighten me.
Q1. the spanning tree protocol is different between 2960X and 3850X. any impact if we migrate the ME to new 3850X?
R: I suggest to you use the same protocol version on whole network, but in theory you wont have problem.
CSTP: working with timers, around 50 seconds to enable a interface to forwarding, it is slowly
RSTP and others: working with agreements proposal, so it is very faster to convergency
Q2. there are some VLAN ID is missing (i.e. VLAN 80), do we need to create it on 3850X before the ME relocation?
R: Yes, it is necessary to create it on 3850x, exemple below to create it;
sw(config):# vlan 80
sw(config):# name AQUINOMEDAVLAN
sw(config):# exit
sw(config):# interface vlan 80
sw(config-vlan):# description AQUIDESCRICAODAVLAN
sw(config-vlan):# exit
Q3. the VTP mode is server. Any impact if I change as "transparent"? Is it configured before or after ME relocation?
R: Changing it to transparent mode is a good practices, because it reset the revision of a switche, that can change all topology if have wrong configurations; In resume: Change it to transparent mode before input in your network
Q4. the new maintenance contractor suggests us to use "trunk mode" to interconnect the 2960X and 3850X (not recommend to use "access mode"). Any idea on it?
R: switchport trunk mode ( will allow other vlans to pass through this conneciton, so in the future if you need pass other networks in between these switches, you do not change anything between the trunks.
R: But is depends of your necessity, you wont have a problem because you input it in "access mode"
Q5. if access mode is changed to "trunk mode", any configuration we need to aware, grateful if you would share it with me.
Your help is much appreciated.
R: well, if you need change it to trunk mode, you can use two commands under interfaces
switchport mode trunk (define interfaces as trunk)
switchport trunk allowed vlan xyz (allow just traffic from specific vlans)
switchport nonegociate (dont negociate trunk mode)
ip dhcp snooping (allow this interfaces as trusted to dhcp packets)
If i can help in any other things, let me know.
Please, mark as solved and helpful all answers that were help you. Because it will helps other people with the same doubts.
04-26-2019 09:19 AM
04-27-2019 10:09 AM
04-27-2019 12:32 PM
@anitaleung2019 Hello,
The configuration below will be used to map a new connection between ME and the two 3850x.
CONFIGURATION ON 3850X
interface portchannel 11
description "CONNECTION_3850X TO ME"
interface GigabitEthernet 3/0/1 (if disponible)
description "Port Channel 11 ME CIRCUIT 1"
channgel-group 1 mode active
interface GigabitEthernet 4/0/1 (if disponible)
description "Port Channel 11 ME CIRCUIT 2"
I think that is not necessary with new connection
04-27-2019 09:27 PM
04-27-2019 09:31 PM
sw(config):# exit
