RSP720-3C-GE all led orange
Ramon flores
Hi, not sure if the right place to do this query.
as indicated by the case, insert the card but all the LEDs are orange. According to documentation, the color refers to a minor fault
The console displays:
System Bootstrap, Version 12.2(33r)SRB4, RELEASE SOFTWARE (fc1)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 2007 by cisco Systems, Inc.
C7600-RSP720/SP platform with 1048576 Kbytes of main memory
Autoboot executing command: "boot "
Initializing ATA monitor library...
boot: cannot determine first file name on device "bootdisk:"
rommon 1 >
message is remarkable, how can I fix this?
Maneesh Lohani
I am sure your issue must have been fixed already. Ran into similar issue today.
I took the console of the standby sup and changed the confreg to 0x2102.
rommon 5 > confreg 0x2102
You must reset or power cycle for new config to take effect
rommon 14 > confreg
Configuration Summary
(Virtual Configuration Register: 0x2102)
enabled are:
[ 0 ] load rom after netboot fails
[ 1 ] console baud: 9600
boot: ...... image specified by the boot system commands or default to: cisco2-C7600-RSP720/SP
do you wish to change the configuration? y/n [n]: y
enable "diagnostic mode"? y/n [n]: n
enable "use net in IP bcast address"? y/n [n]: n
disable "load rom after netboot fails"? y/n [n]: n
enable "use all zero broadcast"? y/n [n]: n
enable "break/abort has effect"? y/n [n]: n
enable "ignore system config info"? y/n [n]: n
change console baud rate? y/n [n]: n
change the boot characteristics? y/n [n]: y
enter to boot:
0 = ROM Monitor
1 = the boot helper image
2-15 = boot system
[2]: 2
enabled are:
do you wish to change the configuration? y/n [n]: n
Rebooted it using 'reset' command. It came up just fine.
HTH.
