I have what should be a simple issue, and I think I may be missing the basics. I am moving a internet circuit from one DC to another. The circuit currently terminates on an ASR 1002 IOSXE 03.06.00.S.
In preparation for the cut over I terminated the SMF (1-GBASE-LX/LH) on a Nexus 5548 to validate the cross connect and that I could ping across the /30 to the provider. This was working after forcing 1000/full and disabling auto neg. (XOs Ciena switch does not do auto neg. and this is forced on their side) here is the port config on the 5548.. The SVI in vlan 750 was in the /30 and could ping.
interface Ethernet1/18
no cdp enable
switchport access vlan 750
speed 1000
duplex full
no negotiate auto
I moved the ASR 1002 and moved the port to the ASR and nothing. Same port and provider we had before. I confirmed with XO that this is the port. And we are seeing correct light levels and polarity (see below.) XO confirms they are not learning a MAC on the Ciena switch but they see the correct light levels and I have called twice and they say all is good in the configuration on their side. I tried a different SFP and the same. I moved the cable back to the 5548 and it works.. The only difference I see is forcing the speed and duplex but this is not allowed on fiber ports on ASR to my knowledge. ARP is flushed on the XO side, and the 5548 was removed last night. /30 is correct. Any ideas here? I do not get ARP from the other side of the /30. I fell like this is basic and stupid but maybe someone can point something out. This ASR terminated another XO internet connection at the old DC for years on this port.
ar1.strlng.clevoh#show hw-module subslot 0/1 transceiver 1 status
The Transceiver in slot 0 subslot 1 port 1 is enabled.
Module temperature = +24.953 C
Transceiver Tx supply voltage = 3302.5 mVolts
Transceiver Tx bias current = 12722 uAmps
Transceiver Tx power = -7.1 dBm
Transceiver Rx optical power = -8.1 dBm
ar1.strlng.clevoh#
ar1.strlng.clevoh#show hw-module subslot 0/1 transceiver 1 idprom
IDPROM for transceiver GigabitEthernet0/1/1:
Description = SFP optics (type 3)
Transceiver Type: = GE LX (20)
Product Identifier (PID) = GLC-LH-SMD
Vendor Revision = 00
Serial Number (SN) = AVJ190436HR
Vendor Name = CISCO
Vendor OUI (IEEE company ID) = 00.17.6A (5994)
CLEI code = WOTRB9YBAA
Cisco part number = 10-2625-01
Device State = Enabled.
Date code (yy/mm/dd) = 15/01/20
Connector type = LC.
Encoding = 8B10B
NRZ
Nominal bitrate = GE (1300 Mbits/s)
Minimum bit rate as % of nominal bit rate = not specified
Maximum bit rate as % of nominal bit rate = not specified
GigabitEthernet0/1/1 is up, line protocol is up
Hardware is SPA-2X1GE-V2, address is c08c.6081.f411 (bia c08c.6081.f411)
Internet address is 66.3.25.xxx/30
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not supported
Full Duplex, 1000Mbps, link type is force-up, media type is LX
output flow-control is on, input flow-control is on
Last input 00:00:07, output 00:00:40, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1069 packets input, 250182 bytes, 0 no buffer
Received 267 broadcasts (0 IP multicasts)
0 watchdog, 802 multicast, 0 pause input
109 packets output, 6574 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
ar1.strlng.clevoh#show run int g0/1/1
ip address 66.3.25.xxx 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
media-type sfp
no negotiation auto
end
